Oil & Fuel ISEKI TS 2205 Excessive crankcase presure?
   / ISEKI TS 2205 Excessive crankcase presure? #1
hdw wild
new zealand
TS2205
Recently I have been working on a ISEKI TS 2205 that builds up oil in the rocker cover, IE. it does not drain back into the sump. Then once it has completely covered the drain holes it gushers it out it filler hole.
This tractor has only done 1,071 hrs.
This I believe is caused by:
1. Excessive blow-by (crankcase pressure)
2. The inability of the drain holes (partially blocked by the push rods) to allow the oils return to the crankcase.
3. No independent crankcase breather. (If anyone knows of a crankcase breather please let me know)
The remedy, short of new rings etc. is obviously to restrict the amount of oil feeding the rocker shaft. Or installing a crankcase breather. But if anyone has another suggestion I would be interested to hear from you.
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
JOHN DEERE 7210R LOT NUMBER 262 (A53084)
JOHN DEERE 7210R...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
