Iseki TL2100f - Lost Hydraulic Dipstick
   / Iseki TL2100f - Lost Hydraulic Dipstick #1
Mark Thompson13
Iseki TL2100 f
Not sure of this is the right place but ive lost the dipstick for the hydraulic system (yes im an idiot). I need to change the fluid. Does anyone have one and can they tell me how long it is so I can make another, I cannot find one anywhere in the world to buy one, Im in the UK.
Hopefully Cheers
Mark
   / Iseki TL2100f - Lost Hydraulic Dipstick #2
If you don't get any answers from someone who has one and can measure, you can figure it out empirically by draining the fluid from all drain plugs (many tractors have more than one) and leave the plugs out overnight to completely drain. Then fill with the exact amount of manufacturer recommended fluid (plus maybe a couple of quarts if you have a loader -you could calculate max loader volume using bore/stroke of all cylinders fully extended plus hose volume using ID and length if you're feeling ambitious), start and run the tractor through the gears and run all the hydraulics through full cycles several times, let set overnight again, then stick a rod or long zip tie in and take a measurement. Then when you fab your dipstick use the measurement plus minus a quarter inch or so
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
New/Unused 2025 CFG QK16R Mini Excavator (A51573)
New/Unused 2025...
FORD 540 TRACTOR (A51247)
FORD 540 TRACTOR...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
