Iseki TL2100 filters
   / Iseki TL2100 filters #1
Doug77
SW Pennsylvania
TL2100F
Does anyone know what air filter and fuel filter (Fram, Napa, etc) fits a TL2100? I am having trouble matching these to domestic filters. Thanks...........Doug
   / Iseki TL2100 filters #2
Doug,
Napa 3262 should take care of the fuel filter.
I've not been able to find a proper USA replacement for the air filter. You can order an OEM Iseki filter element for about $60 or so from some of the guys on this board, or just replace the entire filter assembly with an aftermarket unit from Baldwin or Napa or whoever and then you will have a standard element in the future. It will probably cost $60 for the assembly, but afterwards your elements will be less than $15.
Welcome to TBN!
   / Iseki TL2100 filters #3
I have used the NAPA 8326 in the TL2100. It doesn't have the fins like the original, but it fits otherwise.
   / Iseki TL2100 filters #4
So long as it fits real well, just a little leak by the gasket on the end can toast an engine quickly in dusty conditions. Reed, isn't the filter you are referencing larger in diameter, just barley fitting in the can? Seems like I tried that one once but was concerned regarding how tight it fit, not allowing enough air space???
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
172in Golf Ball Picker (A50325)
172in Golf Ball...
