Iseki TE4370 information
   / Iseki TE4370 information #1
DarrenW
Melbourne, Australia
Iseki TE4370
Hi Everyone,
Just got myself a TE4370 and trying to find out any extra information I can about the tractor.
It came with service and operation manuals which is great, but I'm struggling to find any build year information, and If the TE are just a re-badged TL3700?
Doesn't look like there is much on the net about the 4370 or parts for that matter.
Any info would be appreciated.
thanks!
Darren
   / Iseki TE4370 information #2
Iseki was good at giving a model several different model designations. For example the TX2160 is also called a G174 or G1704. In Japan it would be labeled a TL2700 to Australia it would be a TE4370. It would have been built in the 80's. The Japanese don't get into specific model year to serial #s like US manufactures. I can supply a TL2700 parts book & available parts.
Thanks for the info Leonard.
I eventually worked out the TL3700 was the same as my TE4370.
Luckily the tractor came with a full set of service and operation manuals, so I'm all good in that regard.
Is the White Farm boss 37 the same tractor also? Did you still have a wrecking one of those?
thanks
   / Iseki TE4370 information #4
I still have a FB37 parts tractor. They are close to the TL3700. Pto & throttle are probably different. Could be difference in the transmission.
   / Iseki TE4370 information #5
Hi Darren....
Do you have the manual in an electronic form ?
I have one, and on front looks like a suitcase weight bar, but it is not bolted on by the looks, seems pressed ? Do you have weights on yours & or does the manual give any info on that, such as it being a weight frame and how much it can carry ?
Cheers
   / Iseki TE4370 information #6
Hey guys I have a 4370 here and I need a service manual for it or at least a copy of the pages that deal with 4x4 system so I can repair the 4x4 which is Not engaging
Cheers
   / Iseki TE4370 information #7
I can supply a manual for the US model equivalent.
2008 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2024 John Deere 6110M (A50120)
2024 John Deere...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
