3-Point Hitch Iseki TA270 Hydraulic Side Tilt
   / Iseki TA270 Hydraulic Side Tilt #1
grich
Western Australia
JD 3032E
Hi,
I have a Iseki TA270 4WD (Japanese import) that has a hydraulic side tilt on the TPL. It all works properly and is controled by a 2 way toggle switch mounted on top of the right hand rear wheel guard.
What I dont know about is the 2 knobs on either side of the switch. There is writing on the panel but is in Japanese which doesnt help me.
Does anyone have a similar setup that could help me understand what these knobs actually do?
   / Iseki TA270 Hydraulic Side Tilt #2
Does your machine have a small electric lever to raise the 3 point? On my TA 207 the knobs are used to set how far the 3 point goes up and how fast. If you don't use the electric type lever, they might be to set the tilt when the sensors are used on the tiller.
My TPL is controled with a lever for position and a knob below seat for the rate of rise and drop. But I think you are right regarding sensors that are linked to an attachment. The tractor was used for harvesting tea in Japan where the harvestor used all sorts of attachments linked to sensors.
   / Iseki TA270 Hydraulic Side Tilt #4
I have the original tiller for mine. I took several hours and "Rubix cubed" the controls until I figured out what did what. I then labeled them. I only use a couple of the knobs. I had to put a toggle switch on mine to tilt it. That works fine for me.
   / Iseki TA270 Hydraulic Side Tilt #5
There is a gal from Japan who will translate for a very nominal fee. I have a similar set up on my TA 247 as well as a dozen other emblems in Japanese. i took pics, sent them to her and she marked what they mean and sent them back. If interested, i will send you her e-mail address.
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2016 CHEVROLET SILVERADO 3500 DUALLY (A52472)
2016 CHEVROLET...
JLG MAN LIFT (A52472)
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
