ISEKI TA 215
   / ISEKI TA 215 #1
kingquad
iseki TA 215
I need a operator manual and service manual for my Iseki TA 215 tractor and heard the 1240 massey was the same tractor, is this true or is there a place that sells manuals for this model in english. So far it seems to be a sweet running little machine! Thanks in advance. /forums/images/graemlins/confused.gif
   / ISEKI TA 215 #2
The exact match to a MF 1240 is a Iseki TK527. I don't know how close a TA 215 would be.
   / ISEKI TA 215 #3
Not exactly, but probably pretty close is going to be the 1992-1993 Massey Ferguson 1125.... This was a 4WD model on the same frame as the Iseki TA Series, 210, 215, 230, etc... They are all about the same size, look the same except the 4WD vs. 2WD, and size of engine...
You can look at the engine and find the year it was made which should be the same or close the assembly year.... if I recall it will the the year first then month... 93 02 for example. If not it is 02 93 .....
   / ISEKI TA 215 #4
I have a TA270. I have the TA 270 parts manual and the Massey 1250 parts manual. They share many parts. The TA270 is closer to the Massey 1145. I had a TA215. It is newer than the TA270 . Surge is right on the 1125 being closer. I just put a loader made for MF1250 on my TA270. It fit three of the 4 mount points. I had to do some fitting for the fourth point. Try Jacks Small engines for a manual. They have several listed.
   / ISEKI TA 215 #5
Did you ever find out what the button was for? I just picked up a TA207. It has a green button on the dash and one on the fender under the 4x4 lever. The one on the dash has a lable that looks like it raises the 3 point. But the one under the 4x4 lever just says ON.
   / ISEKI TA 215 #6
I had an importer show me that the year code is also on the front wheels. It is like the one on the engine , 07 91 is one the wheel of the TA207 I just got.
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
