Iseki T6500 (white 2-62)
   / Iseki T6500 (white 2-62) #1
mtnxtreme
Bronze Member
My crankcase is full to the top when I check the oil, although I never over-filled. I was told the hydraulic pump/ or pumps mounted on the left side of motor are leaking into crankcase and need new seals or rebuild. Anyone ever hear of this or have this problem before? Thanks
   / Iseki T6500 (white 2-62) #2
Sounds like you have a seal out of your fuel pump or your hydraulic pump.
Any way to isolate which one, I also have 2 hydraulic pumps mounted back to back on the left side, any way to isolate which one is leaking? The engine is a 4 cyl. Isuzu.
   / Iseki T6500 (white 2-62) #4
If it the little pump on the side it is power stearing check the oil level in the power stearing.it will be low. If it is the main pump it will take oil out of the transmision or hydrualic tank. If it is fuel you should be able to smell it in the oil.
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
2012 PETERBILT 587 SLEEPER (A52577)
2012 PETERBILT 587...
