Iseki SGR19 Wiring/Lighting help
   / Iseki SGR19 Wiring/Lighting help #1
warrenstocks
Iseki SGR 19
Just bought a second hand Iseki SGR19 which I need some help with the electrics.
There are two versions of the SGR19: One which can be operated on the road which has lighting installed & one for off road only use which has no lights fitted.
I presume both tractors share a common loom (??) so does anyone know where I can hook the lighting & switches up to as having a good poke around I see that there are loads of unused multi connectors all over the place?
Many thanks
Warren
   / Iseki SGR19 Wiring/Lighting help #2
If there are any unused loomed wires that are connected to the accessory side of the ignition switch your good to go, if no wire is present then install some red/black 14 gauge wire with fuse connectors from accessory side of ignition switch(should read acc on the back of the ignition switch, then add the toggle switches ,I used a single toggle switches for my back up light and a single toggle for the taillights as well as a single toggle for my front headlights, my tractor only had one working headlight and an old backup light when I first bought it,I sometimes had to drive on the city street where I used the tractor for clearing snow,I also installed a yellow magnetic strobe light on the hood as well, and all these added lights each have their own single toggle switch.....hope this is the info your needin'......Take care....Ampa :)
2018 Ford F-250 Reading Enclosed Service Truck (A50323)
2018 Ford F-250...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
7046 (A50322)
7046 (A50322)
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
