Iseki Hydraulic Filter
   / Iseki Hydraulic Filter #1
Koldsnap
Prince George, BC, Canada
MF 35 / Iseki TU 155
Does anyone know what the Iseki part # is for the hydraulic filter on a TU 155? Thanks for your help.
   / Iseki Hydraulic Filter #2
Howdi. You probably wont need the Iseki part Number for the Hyd Filter or any other filter on your tractor. If you take the filter to Napa they will easily match you up with one that will work. I have never had a problem crossing filters. Also you can go to Wal-Mart and open a few Fram boxes and you will find 5 filters that will interchange. Good luck.
MM.
   / Iseki Hydraulic Filter #3
I don't recommend using will fit hydraulic filters. I've had several customers try that. The filters didn't have enough capacity & starved their pumps. Filters are cheaper than pumps.
Thanks for the comments guys. Sorry it took me so long to reply. Len can you recommend a filter that I should be able to use on this?
   / Iseki Hydraulic Filter #5
The only filter the parts book shows is the pick up screen, which probably would have to be ordered from Japan. Maybe someone added a filter. Can you post a picture of the assembly?
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
Ford Mated Engine and Transmission and 98X6E Transmission (A50325)
Ford Mated Engine...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
