Iseki Field Boss 16 ph
   / Iseki Field Boss 16 ph #1
centell
Bronze Member
Washington, La.
3010 Kubota with 482 frt loader
I have a iseki white field boss 16 horsepower diesel engine that I use to pull a five foot finish mower only. When I crossed over a small ditch the pto and trans. quit pulling. I heard loud noise like the fan was hitting the shrould or the radiator. The tractor would not pull itself. I can run the transmission in all gears including the pto and nothing will move or turn. I belive my clutch disc is striped out. When I engage it gears with the engine running I can hears the noise again. In Nuetral it is quite. Love the little tractor. My only grass cutter. What is your opinion on what i just described. Need your help. Anybody. Where can I get a clutch disc and pressure plate and how much.
Thank you for all the I can get.
James
   / Iseki Field Boss 16 ph #2
My guess is that the spline coupler on the clutch to trans input shaft & one the shafts is stripped. This is a common problem. You'll need to split the tractor either way. We can supply the parts.
Finally someone replied back.
Thank you for replying back. I kind of taught this was the problem also coming from the clutch the way it acted. As soon as I can find time to take it apart I will be in touch with you for parts.
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
Electric Mobility Scooter (A51694)
Electric Mobility...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
