Iseki Bolens Hydrualic pressure
   / Iseki Bolens Hydrualic pressure #1
fixit
Bronze Member
Devon UK
Iseki 2160f
Hi guys i have a Tx2160F / G174 bolans And have just started building a tipping trailer
And was hoping somone here would know what pressure the hydraulic system is set at so i can work out what ram to fit :confused2:
Many thanks in advance Chris
Ps i have posted this in the iseki section as well
   / Iseki Bolens Hydrualic pressure #2
You could check that out by installing a gage and extend the cyl, and read the highest pressure on the gage. Install the gage before the valve. Depending on manufacture and style of cyl, the pressure could be 2500 to 3500 psi. Your interest primarily would be cyl stroke, as any hyd cyl could lift quite a bit. The load will determine the actually pressure.
Just an example.
2 in bore
1 in shaft
2500 psi
4 ton with a straight on push.
Thanks j j i dont have a gauge but i may be able to borrow one i think one of my mates have one.
At least that way i will know the real pressure and not the factory spec that it might not obtain
91013 (A48082)
91013 (A48082)
2004 BMW Sedan (A51694)
2004 BMW Sedan...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2012 DRAGON 200BBL ALUMINUM TANKER TRAILER (A53843)
2012 DRAGON 200BBL...
