Is your AC ready for summer?
   / Is your AC ready for summer? #1
Jabonee
Platinum Member
Pennsylvania
Mahindra
A recent call from a customer reminded me its almost that time of of year for AC. If you have been putting off or have never had your HVAC serviced,now is the time to do it. Some of the simple things you can do or check yourself. One of the biggest complainants I get when its 90+F outside is "My AC isn't blowing cold air" When I inspect the HVAC I find the filters blocked and weighing a pound or two more than they are apposed too. Check and replace the filters ! If you suspect the refrigerant is low take you unit to a certified HVAC dealer. Adding R134 your self may work but you could be over filling the system. Remember refrigerant is put in by weight not pressure on a gauge. A manifold gauge is a diagnostic tool. :snowflake:
   / Is your AC ready for summer? #2
agreed I'll only add check the condenser and hose it out clean. Most of the AC failures I'm called to is a simple lack of maintenance causing one failure or another. Donnie
Absolutely. Good point. :thumbsup:
   / Is your AC ready for summer? #4
I'm sure some would think I'm wasting money, but I allow the company that installed our central air (heat pump) to charge one of my credit cards $12 a month, each month, year round. I don't have to call them; they call me twice a year to schedule a maintenance check-up at my convenience. So you can say I'm paying $72 for each service call, but they've also replaced some things that would have cost me nothing, but would have cost a couple of hundred if we hadn't had that service agreement. We have one of the big filters that only needs changing once a year and they'd do that, too, but I've just been in the habit of doing that myself.
   / Is your AC ready for summer? #5
We have our systems (two) checked out twice/yr. They clean out the two humidifiers as well and check the condensate drains, etc.
I have it on our computer calendars to put vinegar into the drains and to change out the filters every 3 months. Then I do it. Once in Louisiana, we had a service call because algae had stopped up a condensate drain. The drains here were almost plugged with something before I started to regularly use vinegar in them. Initially, I used a chlorine solution, but you do not want to regularly use it.
Our old (20 years on the circulator & about 12 years on the outside heat pump) Lennox system is to be replaced likely next week. Ordered the new 17.5 SEER Carrier system for it. Waiting for them to contact us to schedule it. Carrier has a 19 SEER system, but the 17.5 SEER system was a bit less expensive and seemed to have all the features of the more expensive one (mostly just the heat pump was different).
Ralph
   / Is your AC ready for summer? #6
Tell me more, because I put a cup of chlorine in the condensation drain once a month. Do you think I shouldn't do that?
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
1989 Freightliner Cabover FLA086 (A53472)
1989 Freightliner...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
