Is UDT and UTF Fluid the same
   / Is UDT and UTF Fluid the same #1
casey lb1914
Upstate, New York
Kioti LB1914
Well I might have messed up. I have a LB1914 just changed the hydraulic/transmission fluid/filter yesterday at 105 hrs. I think it was the first time changed since new (I am the 2nd owner). I bought Mystic JT5 from TSC, it says that it is a universal trans-hydraulic fluid. It can be used on Kubota UDT. I read some time back on this forum that any universal transmission/ hydraulic fluid would work as long as it was UTF. If this is the wrong fluid I want to get it out as soon as possible. Any thoughts :confused:
   / Is UDT and UTF Fluid the same #2
maybe oils forum would be best? :~}
   / Is UDT and UTF Fluid the same #3
I'm not familiar with the fluid you have but if it is compatible with K*bota UTD it will be fine.
BTI
   / Is UDT and UTF Fluid the same #4
Posted answer to same question in the lubricants forum.
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
GIYI GY-CWG72- 72" HYD CURVED WOOD GRAPPLE (A51244)
GIYI GY-CWG72- 72"...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
2004 John Deere 6220 (A52128)
2004 John Deere...
LEE G550 MOTOR GRADER (A51242)
LEE G550 MOTOR...
