Gees you would think a recovery driver in a nice rig like that would know he could bend the frame on that trike. Should be using wheel straps. wheel straps for tow dolly - Google Search
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I’d have probably just used a single strap. It would be easy to bend it like that. I’ve about quit doing that since I pulled the brush guard apart in my tractor.
New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
That reminds me of the pic which a TBN member posted a few years ago after picking up his son's new JD pedal tractor... strapped onto the tandem axle trailer because the tike wanted to "Haul it home like Daddy's tractor." :laughing: :thumbsup:
I usually chain the front with the winch cable and hook a second loose chain to keep it from rolling off the back of the truck if the winch cable broke. I usually hook a chain on both sides of the wheel lift and run it backwards until it’s tight. The wheel lift has anti backflow hydraulics so that should be as secure as an other way.
