Is this normal for JD B
   / Is this normal for JD B #1
mitch5777
Hi, just purchased a 1950 JD model B..it runs great, had the distributor
rebuilt and carb tuned. The question is, when I run the tractor in 5th gear
and go down a grade in the road, the tractor idles down even with the
throttle lever in 3/4 open. Is the govener kicking in, or is it starving for fuel?
as soon as it slows down, the speed picks up and runs great.
It doesnt miss when it slows down, it just acts like I have pulled the throttle lever back.
Any help will be greatly appreciated.
Newbie here to tractor collecting
thanks
   / Is this normal for JD B #2
I grew up with those 2 bangers, and they should do that in all gears. just the governor
   / Is this normal for JD B #3
Great engines. My neighbor used a 2 banger engine to run his sawmill.
You will have a lot of fun with that tractor I expect. They are a big hit in parades these days.
   / Is this normal for JD B #4
I don't know much about the mechanical things about the old 2 cylinder J.D.'s (other than running them as a kid), but it sounds as if the governor on your tractor is doing exactly what it is supposed to do.
If it didn't cut the throttle back going downhill with the throttle opened the engine would quickly over rev with all of the unpleasantness that would entail.
As long as it opens the throttle again when it returns to being under load, i.e. going back uphill, I'd say your machine is working fine.
:thumbsup: thanks guys for the information. I knew I would find the right answer on here. I was hoping that it was working correctly. My grand father had one of these when I was a kid. And since I was born in 50 and it was in good shape, I picked it up. And glad I did.
Thanks so much for the help. Really do appreciate it.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 ETNYRE TRI-AXLE DETACH TRAILER (A53843)
2016 ETNYRE...
2016 INTERNATIONAL LF687 (INOPERABLE) (A53843)
2016 INTERNATIONAL...
ELECTRIC GOLF CART (A53843)
ELECTRIC GOLF CART...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2014 MACK CHU DAY CAB (A53843)
2014 MACK CHU DAY...
