is this IH 300 worth putting the effort into?
   / is this IH 300 worth putting the effort into? #1
samsdad02
Rutland
na
Hi all
looking for advice on a possible purchase. It's a International 300 utility with a Shawnee loader. It has been sitting for at least 15 years. Rear rims may need to be replaced from rust, still enough air in them to keep them off the ground. Front tires are junk as are the loader hoses, gauges. left side steering arm ( looks like a pitman arm near the cockpit) is bent, the stop on that side is still attached but barely. right side loader arm has been welded/patched. The guy who has it said when he dragged it to where it is now everything turned free and the clutch disengaged. He's asking $650 for the package.
Is this combo worth the effort? I know its going take some time and money to get going, but don't want to invest too much.
I will be doing the work myself, with (hopefully) guidance and advice from generous knowledgeable individuals :) . It's going to be a working tractor, move snow haul trees and move gravel etc.
thanks in advance.
   / is this IH 300 worth putting the effort into? #2
Assuming the rear tires are usable, I'd probably take a chance @ $650.
IIRC, the 300/350 utility has a history of problems with the steering. Other than that, I don't recall anything bad about them.
   / is this IH 300 worth putting the effort into? #3
With a loader its not gonna be a good one to operate without power steering.
And does it have a 3ph conversion or does it have a 2-point fast hitch. It it ain't got a 3ph that will also make it less usable.
Just.depends on how much you want to put into it and what your plans are.(keep or flip).
New tires and rims can easily set you $1500, and new hydro hoses could be another $500. So you are into it $2650 and don't know if it even runs.
You could easily have $5k+ tied up into it and that's about.all its worth in cherry condition.
I believe it has power steering. Not sure about the rear tires. I will be keeping it at least until I clear the trees, but having let other things go I hope I've learned my lesson.
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2011 Ford F-150 4x4 Pickup Truck (A51692)
2011 Ford F-150...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
