Is this a "Full" Synthetic?
   / Is this a "Full" Synthetic? #1
RFB
Platinum Member
None
Chevron Delo® 400 Synthetic SAE 0W-30, 5W-40
SAE Grade 0W-30 and 5W-40
Product Numbers 235195 and 235194
It says that they are 100% synthetic; is that the same as "Full Synthetic".
The MSDS says "Distillates, hydrotreated heavy paraffinic"
This is the link to the data sheet:
https://www.cbest.chevron.com/generated/MSDS/PDS7668782.PDF
   / Is this a "Full" Synthetic? #2
If it sais 100% then it's 100%. Just depends on what Group of synthetic is in the blend. It is probably a blend of synthetic Group III base stock (which is severely hydroprocessed and made from crude oil but has it's molecular structure changed so it is considered a synthetic) and synthetic Group IV base stock. The advantage of dino based synthetic's (Group III) is that they more easily disolve additives into the blend than Group IV and V do. Group IV and V base stocks usually need alot of different additives to disolve and hold other additives in suspension. The line between Group III dino based base stocks and Group IV and V is starting to blur more every year as technology advances.
In short, Delo 400 synthetic is a good oil. One interesting thing I noticed when I looked up the MSDS's for the two different weight's is that the 0W/30 did NOT list "Distillates, hydrotreated heavy paraffinic" while the 5W/40 does.
DP,
In your estimation, how does the Delo 5W-40 Synthetic measure up against Mobil 1 Turbo Diesel Truck 5w-40?
   / Is this a "Full" Synthetic? #4
From the UOA's I have seen over the years it performs well in extended drain interval applications and holds it's weight against M1 TDT.
Utility Trailer (A52377)
Utility Trailer...
30ft Highway Trailer Co. Lowboy (A55218)
30ft Highway...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
