Is there an R2 Tire Tread?
   / Is there an R2 Tire Tread? #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
I know what R1 tires are, and R3 tires, and R4 tires.
Is there an R2 tire tread? What does it look like.
Just curious.
Pooh Bear
   / Is there an R2 Tire Tread? #2
Pooh Bear:
There is a R-2 tread. It is used in wet farming (mud/standing water) application. The tread is twice as deep as the standard R-1 tread. While the R-2 tread looks extremely aggressive, the typical 45 degree bar angle is maximized for cleaning in wet soils and is not as efficient for developing traction as R-1's.
There is also a R-1W tread which originated in Europe and has a 20% deeper skid depth than the R-1 tire. They are designed for better highway wear.
I believe that I downloaded this informaton from Louisiana State University. Agricultural Equipment Technology Conference (2/8-10/2004), Titled "Choosing the Right Tire" Publication # 913C0204
Hope this helps- Jay :)
   / Is there an R2 Tire Tread? #6
If you go to the Firestone site, you might want to look at their logging tires. they look like ags or R4s, but the ply rating is on the high side of 10 -- way high in some cases -- and there are some treads you won't see in other places.
   / Is there an R2 Tire Tread? #7
Firestone calls their R-2s Spade Grips. Here's a pic:
   / Is there an R2 Tire Tread? #8
There's also a variant of turf tire, but I cant find them. Their tread looks like a bunch of square or rectangular "blocks" some are even diamond shaped. Like beefier verions of the pillow turf tires you normally see.
   / Is there an R2 Tire Tread? #9
   / Is there an R2 Tire Tread? #10
You may be thinking of the XM27 radials?
jb
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
