larso1
Hi guys,
I was going to check the condition of the HW t-stat in my tractor...never did before. Well, in the Bolens G194 manual (closest thing I have to this actual Iseki model) there clearly shows a bolted, rounded casting on top of the upper HW hose connection to the motor with a t-stat sandwiched inside as you would expect. But on my tractor, which also has a water pump, there is no such casting....only a fabricated 90-degree turn fitting that has no t-stat inside. Is there one somewhere else in the system...or does it not have one? Seems like it should to get up to proper operating temp. Thanks in advance for your replies.
Bill in CO
Bill in CO
