Is there a quicker way to do this?
   / Is there a quicker way to do this? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I just finished a long thread titled, 'Any tips for 1 man implement hook-ups?' While reading, I did what I've done so many other times before. I opened a tab for, Tractordata.com, so I could check to on the size of tractor owned by the person making the post. I needed to know this to see whether their ideas might work for a tractor in the size range as mine. After all, a tip that works for a Steiger, might not apply to my utility tractor.
Anyhow, the process of accessing the correct makes and models took a while and I was wondering if anybody knew an easier way.
   / Is there a quicker way to do this? #2
Not sure what you mean by "took a while" but I have Tractordata in my favorites bar. So I click on it, click on brand and click on model, seems simple and quick enough to me.
   / Is there a quicker way to do this? #4
I just type the tractor make and model into Google and the related Tractordata page is usually in the first 10 items that come up in the search.
EDIT: There is also a search bar on the top of the tractordata page.
By 'took a while' I meant that In a long thread I had to do it several times and the minutes to look up each tractor added up.
I have Tractor Data on the home page of my tablet but, all the steps required take time.
I may try that. Thanks.
   / Is there a quicker way to do this? #7
my tractor model site:tractordata
add the www. and the .com to tractordata
the "site:" tells google just to search that site and no other website.
you can also create a "custom search" if you have a google account. that you can add a specific set of sites to search.
   / Is there a quicker way to do this? #8
I usually have tractordata as an open tab along the top bar of the screen. That way, I just click between the tabs (pages) and look up whatever I'm looking for... Sometimes do the same with Nebraska test page, too.
AKfish
   / Is there a quicker way to do this? #9
When I read this thread I thought why don't we put a picture of our tractor in our signature. So I did. Hope it helps.
Mini trencher attachment (A53421)
Mini trencher...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2011 JOHN DEERE 323D SKID STEER (A53843)
2011 JOHN DEERE...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
