is there a difference between a 2520 62D and 2320 62D deck?
   / is there a difference between a 2520 62D and 2320 62D deck? #1
purpony
CT
JD 2440/JD 3020/JD 314/JD 345/JD 850/JD 2320
I was wondering... is there a difference between a 2520 62D and 2320 62D mower deck? Just the deck itself? My dealer is trying to tell me there is. He says a 62D deck off a 2520 will not fit a 2320..... anyone have any input on this?
   / is there a difference between a 2520 62D and 2320 62D deck? #2
Not likely a difference in the deck, but very likely there is a difference in the hangers and brackets that fasten that deck to the particular tractor. Interchanging decks can get to be a headache and the dealer is trying to avoid that problem.
Are you trying to upgrade tractors and keep the deck?
   / is there a difference between a 2520 62D and 2320 62D deck? #3
I thought the decks were the same, but in another thread someone (who probably knows a lot more than I do) said there are two different 62D decks because of the difference in front wheel tread width between the 2520 and 2320. The difference is apparently in the placement of the drive over ramps.
   / is there a difference between a 2520 62D and 2320 62D deck? #4
The deck shell is the same, but the drive over ramps (see above) as well as all of the attaching parts are different. All of the attaching parts could be switched over, but the fact that the ramps are different make it so that the two decks are not interchangeable
no, i just bought a 2520 62D deck that the trucker picked up this morning with plans to install it on my 2320. I was calling my dealer to order a 2320 lift kit for it and he is was saying that the decks are different!... then he proceeds to tell me just 2 days ago he took in a used 62D with all the install parts needed for the 2320!. WTF!!! lol.... nothing is ever simple.
   / is there a difference between a 2520 62D and 2320 62D deck? #6
Well, I'm not following what's up very well, but wish you the best getting it straightened out. ;)
   / is there a difference between a 2520 62D and 2320 62D deck? #7
The shafts are also different lengths. I have had both the 2320 and the 2520.
   / is there a difference between a 2520 62D and 2320 62D deck? #8
According to my manual the 62inch drive over deck for the 2320 is Model No. 62D1. The deck for the 2520 is Model No. 62D2. The 62D2 model is also used for the 4115.
The deck on my 2520 is indeed a 62D2.
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
Hyster H225E Forklift (A47477)
Hyster H225E...
