Is There a Bearing X-Pert in the House
   / Is There a Bearing X-Pert in the House #1
SandburRanch
Veteran Member
NHtd75
A 6203 ball bearing seems to be a common bearing for several applications. But they all seem to have other numbers and letters following the 6203. Example: 2RSJEM,
2RS,RS
2RS1
Is anyone familiar with these number/letter designations or know where there is a chart that will de-code them and tell what they mean. Thanks
   / Is There a Bearing X-Pert in the House #2
Here are a few codes ; rs= one seal , rsz = seal on one side shield on other ,z = one shield , znj =shield on side opposite snap ring groove , n =snap ring groove onouter ring , j = steel cage . The number 2 preceeding suffix indicates double seal or double shield . I hope this helps you .:thumbsup:
   / Is There a Bearing X-Pert in the House #3
There are also C1, C2, C3, and C4 (3 and 4 are the two we work with) which refers to the internal clearance in the bearing. C3 is the most common. I have a whole page of bearing codes at work.
Kim
   / Is There a Bearing X-Pert in the House #4
Some manufacturers have bearings made to their specs and the suffix doesn't mean anything to anyone but them better to take bearing in hand and match it up with seals/or not and dimensions.
Some have snap ring grooves and that means something sometimes also. Yes a 203 is a common bearing.
   / Is There a Bearing X-Pert in the House #5
   / Is There a Bearing X-Pert in the House #6
Here is a good link to a general overview of bearing types and numbering systems used by common manufacturers.
Gregory Bender - Bearing cross reference
Also, if you are having trouble finding bearings, check out
Bearing Location Service - Timken, Ntn, Ina, Skf, Link-Belt, Dodge
They deal with all types of bearings, call you back within 30 minutes of your email and are really helpful. Not too automated, but they found me five different bearings I needed to replace in a 1950s piece of farm equipment. Highly recommend them.
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
Panorama 8 Wheel Rake (A50515)
Panorama 8 Wheel...
2020 Nissan Altima Sedan (A50324)
2020 Nissan Altima...
