is there a 12VDC accessory wire on TYM T394?
   / is there a 12VDC accessory wire on TYM T394? #1
jheimann
TYM T394 HSC
I am the owner of a brand new TYM T394 Cab tractor. I need to find a 12VDC connection point to wire in the electric shoot rotator and deflector on my 3 point hitch snow blower. Does anyone know where I can find a 12VDC connection point? I don't want to use the cigarette lighter as it will not have enough amperage to run the rotator (requires 10 amps and most cigarette lighters are 5 amp).
Any help on where to find a 12VDC connection point on the tractor that is switched with the ignition switch would be greatly appreciated.
Thanks,
John
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
