Is the PTO hard on transmission /hydraulic oil in cut?
   / Is the PTO hard on transmission /hydraulic oil in cut? #1
ATP
Bronze Member
Land Between the Lakes
John Deere 3038e and LS K 5047
I have a cut tractor. ..and I use the pto to finish mow and bush hog a bunch. Does PTO work the hydro/tranny oil as hard or harder that hydro transmission or front end loader work ??
   / Is the PTO hard on transmission /hydraulic oil in cut? #2
,,,No
Thanks. Good to know.
   / Is the PTO hard on transmission /hydraulic oil in cut? #4
If you are worried about it and that's your only concern with your aspirations, just change your oil and filter more often ensuring that you use the type of oil that is specified for your tractor....like the Premium orange stuff that is made for hydro's, wet brakes, steering, tranny, PTO, and diff. In short, JM20C
   / Is the PTO hard on transmission /hydraulic oil in cut? #5
Does it work it "harder", not really. Does it work it more, yes. The main thing that is going to deteriorate the oil is heat and the pressure generated by the pump will create heat. But that is why you have a tractor isn't it? The manufacturer's service intervals take that into account. But like Texasmark said, if it concerns you, change more often.
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
45050 (A51694)
45050 (A51694)
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
