Is the plow better than bucket for removing boulders?
   / Is the plow better than bucket for removing boulders? #1
ragkar
Platinum Member
eastern PA-lower Poconos
JD2320 w/R4 $21,100 w/7.16%off
A bit ago I mentioned to an old farmer that I had better success digging up small boulders (1-2 ft) using my plow attachment than when I was using the fel bucket. The farmer said that I was having trouble with operator technique!
I like the plow because I can see the cutting edge, whereas the bucket and teeth are guesstimates.
What do you guys think is better?
   / Is the plow better than bucket for removing boulders? #2
Grab your most expensive implement. It will always find the boulders.;)
I use my middle buster plow for doing just that. Everybody has their own way.
   / Is the plow better than bucket for removing boulders? #3
What ever works.
A box blade with the scarifier teeth down all the way will grab them and lift them to the surface. Don't try it if you bought a cheap box as it will be hard on it.
   / Is the plow better than bucket for removing boulders? #4
I love my frame mounted front blade, but I would think the loader bucket would work better. More leverage.
Sincerely, Dirt
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
197711 (A51244)
197711 (A51244)
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
