Hi trook,
I have a med. duty 6' Woods (BB720) and an
L4300 (same size predecessor to the
L4400). The 4300 is NOT enough tractor for the BB720. It will run it and once it gets the blades spun up, seems to have enough power. The big factor is weight.
The BB720 weighs around 1200lbs. (with chains). The Kubota Operator Manual for the
L4300 has a table which lists the max. recommended weight/size for a variety of implements. For the rotary cutter, Max weight is 880 lbs., max. size is 6'. The problem is that the weight is centered about 3 feet aft of the 3PH and applies lots of leverage to the tractor.
When running the 720 behind the 4300, it seems like the tail is wagging the dog. The big heavy mower swinging around tight turns has got to be putting real stress on the 3PH. Without the FEL on the front, you can't raise the 720 clear of the ground without pulling the front wheels off the ground. I used it without the top link (2 pt.) for awhile and that did work but it's not optimum.
What's really a PITA is that the 3PH geometry on the tractor (smallish Cat I) is too tight for the CatII dimensions of the cutter. Hooked up, everything matches but the 3PH arms are spread nearly as wide as they will go...which means that to get hooked up, you have to partially disassemble the 3PH. From what I've seen of the
L4400, you'd be faced with the same thing.
I bought the two together and my dealer recommended the standard duty 6 footer instead. I went ahead with the 720 under the rationale that I had a bigger tractor to pull it if necessary (old Ford 4000). After using the cutter on the Kubota a few times, the Ford and the BB720 have become practically inseperable. Even the Ford gets a bit light in the front at times and is not ideal. I'm hoping to upgrade it to a M-series in a couple years.
I'd recommend Woods new Extreme Standard Duty BB72 if you stick with the
L4400. Woods Standard Duty cutters are pretty tough. I just sold a 30 year old 5 footer to the neighbor. It was rough and the deck starting to crack, but still did the job after loads of abuse.
If you must have the Medium Duty, you should be looking at the smaller M-series tractors...I think the
M4800SU or the
M5040 would be the smallest to comfortably handle it, from what I've read. The MX5000 is limited to around 1000lbs. with a rotary cutter, so it doesn't make the cut.
Again, it's not the HP that's the big issue, it's weight and how it's distributed. The 5103 is heavier and would probably be a better choice than the
L4400, but check with the JD dealer.
Definitely get 4WD...it'll keep you going instead of cussing.
Sorry this is so long, must have keyboard diarrhea this morning.
FWIW
Bob
