Is the Kubota B2650 a large frame B Series tractor?
   / Is the Kubota B2650 a large frame B Series tractor? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Looking at purchasing a Kubota B2650. Is the 2650 a "large frame"
B Series tractor like the B7800?
Also, what Kubota models does the 2650's MMM fit, other than the B2650?
And, what other Kubota models does the 3ph grass bagger fit, other than the 2650?
Is the 2650's HST different than the 7800's HST?
   / Is the Kubota B2650 a large frame B Series tractor? #2
Tractor weights listed on the Kubota web site will tell you.
Have you shopped the Kubota L2501?
From what I see at Tractordata.com, the 2650 weights a few more pounds than the 7800 and the wheelbase is the same.
A dealer told me today that the 2650 took the place of the 2920 and that it had a smaller frame than the 7800 due to the
26hp engine.
Have not shopped the L2501. Should I?
   / Is the Kubota B2650 a large frame B Series tractor? #4
L2501: No Tier IV, 2,623 pounds/HST, bare tractor.
No mid-PTO.
   / Is the Kubota B2650 a large frame B Series tractor? #5
26hp engine.
Dealer is wrong. 2920 was smaller than the new 2650.
If you look at the previous generation, the 2620 and 2920 were the same "mid" size B, only differing by engine/HP. The 3200 and 3300 were the "large" frame size B, and bigger than the 2620/2920. All of those B's were basic models.
The new 2650 and 3350 are the same size as the old 3200 and 3300. The 2650 and 3350 are deluxe models, however. They differ from each other only by engine/HP and tire size.
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A49461)
2014 Peterbilt 320...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
