Is the B2733 Quick hitch compatible with a BX24?
   / Is the B2733 Quick hitch compatible with a BX24? #1
psd
Warwick, NY
Kubota BX24TLB
Hello everyone, I have a BX24 and am looking to purchase a BX2763A Blade. I may be able to get one with a B2733 Quick Hitch which was made for the B7500. My question is does anyone know if that quickhitch is compatible or do I absolutely need the B2751?
Thanks for the responses.
Pierre
   / Is the B2733 Quick hitch compatible with a BX24? #2
Hmmmm... I don't believe, right off hand, that anything designed for the B series will work with the BX. The front ends are different, really.
The plow itself is interchangeable, but the QH subframes... there's the rub.
   / Is the B2733 Quick hitch compatible with a BX24? #3
Anything is possible to remake but I'd hold out for the right hitch.
   / Is the B2733 Quick hitch compatible with a BX24? #4
PSD,
I just went down this road. I got a B2781 with a quick hitch, but not the 2751. Won't fit, no way. no how. Too long in the shaft, too short in the front, & none of the bolt holes line up with anything on my BX22. I'd wait & get what you need, As an option until you find what you want try BXpanded.com. Good looking gear, bolt/clamp on & go.
HTH T-Man. :cool:
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
