What is the relief setting for the BH according to the manual?
If the pressure is set per manual, leave it as is, and the BH will relieve when the pressure gets to 2025 if that is the correct pressure. If the BH can use more pressure, plug in a gage in a tee at the IN port of the BH and set the relief. It will have more power.
Usually, all the reliefs are set the same as the FEL relief. So if any of the other valves that use system fluid has a pressure above the FEL, it will never go off as the FEL will relieve the fluid for every hyd function.
