Is my Optima battery bad????
/ Is my Optima battery bad???? #1
computerboy
Bronze Member
Illinios
NH TC25D
The other day I noticed the battery in my New Holland TC25D leaked acid all over again. The first time it happened my dealer gave me a new battery and parts that rusted. My warranty is up so I decided to go with an optima to eliminate the problem. In doing searches though the previous posts, it looked like the Red Top 75/35 should work. I went looking and found a place that carries the red top 75/35 but they were out of stock until 7/22. The sales person said the red top 35 was the same but without the GM posts. Since I was only going to use the top posts it sounded good - plus they were on sale. I got home removed all the parts, cleaned everything and painted them. It was getting late and I needed to call it a night. The paint was not dry on the parts so I decided to connect the new optima using a piece of plywood as the base so I could back the tractor into the garage. When I went to start the tractor it did not turn over. /forums/images/graemlins/confused.gif I have lights. The dash lights works correctly, including the glow plug light goes out after a few seconds. When turn the key to start the tractor -- nothing -- not even a single crank. I put the old battery that leaked all over back in and it starts right up.
Any ideas? Did I get the wrong battery? Is the red top 35 not the same as the red top 75/35? Is the battery bad? How can I check the battery?
Thanks,
Mike
/ Is my Optima battery bad???? #2
You can only check the battery accurately with a load test which requires some equipment you may not likely own.
A CSK or AutoZone parts type place should be able to test it for you. It may just be discharged. An Optima that is on sale has likely sat around a while prompting a price reduction.
Do you have a charger? If you charge it over night and it still wont crank its time to check the starter. A test light on the small wire to the starter and the test light clip to ground will tell you if juice is getting to the solenoid with the key in crank position.
If you have a fully charged battery and juice to that wire and clean tight batt. connections your starter is bad.
If no juice there when crank position, check any interlocks: clutch safety switch, etc.
The group 35 is like you say---just void of GM side terminals.
They are all in all awesome batteries.
Check polarity too, battery terminals to the correct spot---i've never made that mistake, but have seen it done....lol
Usually theres big sparks though in that case.
(Mark gets off his self pontificating pulpit of self righteousness and never making an electrical mistake and struts away....) /forums/images/graemlins/grin.gif
/ Is my Optima battery bad???? #3
If the old battery works and starts the tractor fine and the new one doesn't then I think the problem is with the new battery. Charging it over night is a good idea. If it won't turn your motor over after the over night charge I would take it back to the place you purchased the battery and have them check it out or give you a replacement.
/ Is my Optima battery bad???? #4
I could be wrong but would assume he turned in his old unit as a core??? /forums/images/graemlins/crazy.gif
/ Is my Optima battery bad???? #5
</font><font color="blue" class="small">( I could be wrong but would assume he turned in his old unit as a core???
Here's a quote from his message.. he states he still has the old leaky battery.
)</font>
</font><font color="blue" class="small">( I put the old battery that leaked all over back in and it starts right up.
)</font>
My vote is for a discharged battery.. or dirty terminasls.. or reverse polarity..
Soundguy
/ Is my Optima battery bad???? #6
I put a Red-Top35 in my kubota last year. The suggestion of dirty terminals (or just not tighetned down?) would be my guess if the battery was charged. I know you didn't ask, but I would be concerned why the old battery caused problems in the first place. Overcharging causes gassing in lead-acid batteries, chronic overcharging is at least one cause of the original problem you describe. The Optima "recombines" the gassing back into it's original state, but it can be overwhelmed if (severly) overcharged & vent. I am not sure, but I believe the battery is damaged if it vents. Have you or the dealer checked the charging system to ensure that it's putting out around 13.8 - 14.5 volts?
I will try putting it on the charger to see if that helps. I have checked the polarity a couple of times to make sure it was correct.
I did not take my old battery in for exchange just incase something like this happened. They gave me a slip to bring my old battery in to get $7.
I forgot to say all the optima batteries were on sale, not just the battery I purchased.
/ Is my Optima battery bad???? #9
I hope I don't rain on your parade.... /forums/images/graemlins/smile.gif
I bought an Optima Yellow Top (51R) for my TC25D and had the same problem. I exchanged it for another one. Same problem. I charged it overnight. Started the tractor fine, so I finished up the installation. Tried to start the tractor the next day, wouldn't start.
I pulled the Optima out, put in a battery I got at Tractor Supply, been running fine ever since.
Others have installed Optima batteries and didn't have a problem, so I'm confused why they wouldn't work in my situation.
The first time I saw the problem my dealer gave me a new battery and new parts. He said only one other customer had this problem and the new battery fix it. I did this last fall. There were no problems with battery all winter removing snow and this spring and summer cutting grass until last week. I have been installing a couple of retaining walls and I drive over some bumpy ground to dump my excavated dirt in a washed out area. I assume all the vibrations and bumpy conditions caused the battery to leak. I could be wrong. If charging the battery does not help, I will return the battery and talk with my dealer. Either way I will talk with my brother to help me test the charging system.
Thanks,
Mike
/ Is my Optima battery bad???? #11
We have been using an Optima for a year and a half without a minutes worth of problems. I might suggest taking yours back and let them test the Optima battery, that way if there is a problem they can take care of it.
/ Is my Optima battery bad???? #12
Go to Harbor Freight tools and get yourself a $3 volt/ohm meter and check the battery. If at least 12.6 volts, it's good. If less, put on charger, ($30 from Advance Autoparts), until fully charged. If it won't take/hold a charge, return it.
/ Is my Optima battery bad???? #13
Another trick I've used when trying to figure out the trouble is to leave those lights turned on while you attempt to start the tractor. If the lights dim when you try to start it then the battery is not providing enough juice. If the lights stay the same then the problem is not the battery.
I have had an optima in my pickup for several years and really appreciate the lack of corrosion and acid. I would use one in my tractor in a heartbeat.
My current bulldozer battery is pretty juicy. My voltmeter reads 15 volts from a new GM 1-wire alternator. I wouldn't say a juicy battery in a non-road vehicle is a big problem. Lots of sloshing going on there. I use a full plastic battery box from walmart to contain the acid and prevent the battery from bouncing into the hood.
I put the battery on my charger this morning and after a few minutes the charger went into desulfation mode. /forums/images/graemlins/confused.gif Here is what my manual says about it.
DESULFATION MODE: If a battery is left discharged for an extended period, it could become sulfated and not accept a normal charge. If the charger detects a sulfated batery, the charger will switch to a special mode of operation designed for such batteries. Activation of the special desulfation mode is indicated my blinking the CHARGING LED. If successful, normal charging will resume after the battery is desulfated. The CHARGING LED will then stop blikning and light continuously. Desulfation could take up to 10 hours. If desulfation fails, charging will be aborted and the CHECK (red) LED will blink.
After reading this I decided to call the place I purchased the battery from and asked if they could test it. They said they could so I took it back. They tested the battery and it came up bad. I exchanged the battery for a new one (same model). I had them test the new battery and it tested out fine. I just got back, hooked it up to my tractor and it started right up. /forums/images/graemlins/smile.gif
Thank you to everyone who replied with suggestions. I am new to the battery stuff so I learned a few thing from the replys.
Just for my information, I have a Schumacher Speed Charge Smart Battery Charger Model 1200A For 12-Volt Batteries. The charger has 3 options for types of batteries - Regular, Deep Cycle and AGM, Gell Cell. Is it OK to use the regular setting for the Optima battery or should I use the Gell Cell option? Here is what the manual says:
REGULAR: This is the type of battery usually used in cars, trucks, and motorcycles. These batteries have vent caps and are often marked "low maintenance" or "maintenance-free".
DEEP CYCLE: Deep cycle batteries are usually marked as "deep cycle" or "marine". Deep cycle batteries are usually larger than the other types.
AGM, GEL CEL: AGM and gel cell batteries have sealed cases without vent caps. Such batteries are often smaller than the other types.
Again - thanks,
Mike
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
(2) 300 GALLON POLY TOTES W/CAGES (A60432)
(2) 300 GALLON...
2011 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A59904)
2011 INTERNATIONAL...
