Buying Advice Is it worth the upgrade from EZT's to ZT-2800 transmissions?
   / Is it worth the upgrade from EZT's to ZT-2800 transmissions? #1
MattWH
Charlotte, MI
None yet!
Hello. First-time poster here. I am in the market for a good ZTR mower since I recently bought a small place out in the country and will have about 2.25 acres to mow. I have a budget of $3,000-4,000, but wanted to keep the cost to the lower side of that range.
I致e been doing a bunch of research and trolling the forums (thanks for all the people who post good advice here!). I am very interested in the Toro TimeCutter SS5060, which has a bunch of great features: 50 cut, Kawasaki engine, foot-assisted deck lift, and dual speed ranges. Like most ZT痴 in this price range, the drive transmissions are HydroGear EZT痴. Toro does offer a MX5060 which is identical except for a fabricated deck and ZT-2800 drives for about $600 more.
I know the fab decks are more durable, but with the yard I will be mowing I think a stamped deck will hold up just fine. The real selling point for me would be the larger hydros. I知 just wondering if it痴 worth the extra $$. It seems like any of the residential units that come with the ZT-2800痴 will start around $4k (JD Z425, Dixon Ram 48ZT).
The yard is relatively flat, and there will be a low-moderate amount of maneuvering around obstacles. One concern I do have is that I知 a pretty big guy (260 lbs.) so I need plenty of torque to spin my fat @$$ around :) I just don稚 want get into the big bills of replacing hydros after 5 years.
Thanks in advance for any advice.
   / Is it worth the upgrade from EZT's to ZT-2800 transmissions? #2
This is just my opinion, so FWIW. EZT stands for "Economical Zero Turn". My experience is when a manufacturer puts an "Economical" transmission on a mower, it is usually also reflected in the rest of the mower. You probably won't notice a difference for 2 to 3 years. After that you'll probably start to get into the "get what you pay for" mode.
For instance, we bought a Gravely ZT about 4 years ago at work. Mowing about 1.5 acres that is rough in a few spots, we've worn the mower out. The transmissions are sluggish and feel tight. It has the EZT's.
Two years ago, I bought a Hustler with the ZT-2800's. We mow about an acre of yard and about 3 acres of pasture converted to orchards. It feels as good as it did when new. There is a reason it has a 5 year warranty and the Gravely has a one year. (Both mowers are fully serviced per the maker's recommendations.)
So, IMO, it depends on how long you expect the mower to last.
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
2016 Ford F-450 Ext. Cab Knapheide Stakebody Flatbed Truck (A50323)
2016 Ford F-450...
