Is it time to consider electric?
/ Is it time to consider electric? #162
That could be one advantage for buying a brand for which there are aftermarket batteries that simply plug into the mower. With some of the battery mowers, they don't even tell you what batteries they use or where you can get them.
/ Is it time to consider electric? #163
If there was no aftermarket battery's for some tool I was contemplating, this would devalue it by 50%.
/ Is it time to consider electric? #164
Here are some Ego battery's found on Amazon. Can't say they are good or bad.
/ Is it time to consider electric? #166
Amazon has aftermarket battery's for them. I can't comment on these but aftermarket ones for my Makita tools have been pretty good.
I had aftermarket Black and Decker NiMH batteries that were better than the OEM batteries.
I had an aftermarket Milwaukee M18 Lithium that was complete junk. Dropped it once and dead.
I've been reluctant to get other aftermarket batteries, but perhaps it is worth reconsidering.
/ Is it time to consider electric? #167
When I was running dewalt cordless tools X years ago, the aftermarket battery were 100% junk. It took a few years but they eventually did make good ones and this is why I'm looking at a Ego mower. Its been around for a few years AND battery's are available.
/ Is it time to consider electric? #168
When I was running dewalt cordless tools X years ago, the aftermarket battery were 100% junk. It took a few years but they eventually did make good ones and this is why I'm looking at a Ego mower. Its been around for a few years.
Both Greenworks and EGO have been around for several years, and make good electric equipment.
EGO has settled on 56V batteries, and stuck to it. So, all batteries are more or less compatible.
Greenworks has 24V, 40V, 60V, 80V, and 82V batteries. Perhaps even other orphaned batteries. A nightmarish mess. And, the 80V and 82V batteries are similar enough that it is crazy to have made the distinction. I have a rib on my 82V saw that I need to chisel down to make both fit.
I haven't tried the aftermarket Greenworks batteries (I don't run EGO). Perhaps I'll give them a shot. I've purchased used batteries on E-Bay from time to time with good luck, but got a few bad ones recently. :(
/ Is it time to consider electric? #169
We have a Greenworks 40V string trimmer that we bought a couple years ago. Wife can't pull start any engines due to shoulder issues. The battery stopped taking a charge after the 3rd use. I called them. They sent us a new one right away. It's still working 2 years later. So we'll see.
/ Is it time to consider electric? #170
I keep speaking of this Ego zero turn I'm "going to get" which still sits in storage at my dealership... :ROFLMAO:
/ Is it time to consider electric? #171
The Makita aftermarket batteries I have gotten were not very good.
I am a big fan of electric (battery) mowers but when you need 6 batteries, $500 each does hurt. Almost makes sense to just buy a second mower and have spare parts. I did that for some of my previous battery mowers.
I now have a Makita self propelled battery walk behind mower and love it. No hearing protection really needed. I need 6 batteries to do the 1.5 - 2 (?) acres that I use it on but at $50 each for the real ones, it is not so bad. It is nice that it takes the batteries my tools use so I get more bang for my buck. But comparing what a walk behind needs vs a zero turn is definitely an apples to oranges comparison.
/ Is it time to consider electric? #172
Remember the construction company that bought CASE Electric backhoes, then they had to buy huge diesel generators to charge them all night.
I know someone has the picture.
The vast majority of the US electrical grid does not support 480 three phase. The three phase 480 is found mainly in industrial complexes in the US.
It was probably thousands of dollars cheaper for the company to purchase a generator than pay for upgrading the electrical service to 480 three phase.
/ Is it time to consider electric? #173
And I'll have there zero turn in the next few weeks. They make a regular garden tractor, walk behind and 2 zero steer venisons.
And an ice auger!
/ Is it time to consider electric? #174
And an ice auger!
Hmm, sounds great, but don't let the battery get too cold before using it. Lithium batteries lose performance below 32F...
All the best,
Peter
/ Is it time to consider electric? #175
All the best,
Peter
People that have battery augers say to put the batteries in a soft-sided lunch cooler if the temps drop below 25ish and maybe toss in a hand warmer. That's about it.
/ Is it time to consider electric? #176
Or make sure your battery is larger than you need. I thought everyone has been doing this for decades who use batteries in cooler temps.
/ Is it time to consider electric? #178
Wait a minute. I have never heard such brazen statements. My God next thing one knows, you two will be advocating for personal accountability and responsibility. :D:cool:
/ Is it time to consider electric? #180
I will say, I have 5-6 different ice augers. Had a gas one for many years. Rarely used it. First, ice was never that thick, rarely over 8". Second, seemed to never failed to smell like gasoline in my gear, no matter how careful I was. I've been out with a few folks that at first used 18V drills adapted to auger bits, then bought real battery operated augers. They seem to work just fine and less hassle.
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2017 John Deere 825i XUV Gas Utility Cart (A59228)
2017 John Deere...
John Deere 1025R (A53317)
John Deere 1025R...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
