I am fixing up a John Deere 2130 that the previous owner ran low on hydraulic fluid because of leaky seals on the lift arm. First, we fixed the brakes, one of which had frozen. Then, had to replace the reverser shaft. Now, it starts up and will work fine for a few minutes, then the power steering goes out then the tractor won't work properly.
Cleaned out all the lines to the main pump, checked the screens and replaced the filter. Fluid still not getting to main pump. Before I bite off another project on this thing is there a way to isolate the problem as to whether the main pump is the issue or whether the main pump might also need replacing? I am not sure I want to do both.
Also, based on the above how confident would I be in saying the trans pump is the issue?
Finally, would I have to replace the entire trans pump or just gears?
Thanks.
Thanks.
