is it safe to use a tractor to pull over a tree
   / is it safe to use a tractor to pull over a tree #1
roermo
Hannibal MO.
4110 JD
Want your opinion about bringing down this mulberry tree. It is about 20 or so inches across and 45 ft tall (about). My neighbor cut down three other trees and he hired a professional to cut those trees. They were much bigger and closer to his house. I used my tractor to hull off the trunks. The neighbor and logger said to cut a notch on the left side of the tree, cut from the other side and use my tractor to pull on the tree on the notch side. Tie the rope up high.
My question is this. Is it safe to do this with my 4110 JD. It weighs about 1700 pound and maybe 250 with the bucket. I think it would work but if things would go wrong I do not think my tractor would be a match for the weight of the tree and I think it would pull it backwards or even up and back. Should I tell the neighbor to use his truck instead. Getting the truck in the back is tough so they want me to use my tractor. Any thoughts.
Roger
   / is it safe to use a tractor to pull over a tree #2
It is not worth damaging your tractor or brains if something were to go wrong. You will need a serious chain to get this done right anyway. Do yourself a favor and be safe instead of sorry. Once that tree lets go it is going to fall way faster than you are going to pull it over. This is why people pay professional tree loppers.
   / is it safe to use a tractor to pull over a tree #3
I agree with Mike... there's no second chance once the tree begins to fall. Gotta make sure everything is done safely the first go around.
   / is it safe to use a tractor to pull over a tree #4
Look at your first picture - see the way the tree is leaning and the amount of overhang on the branches ..... that some pretty serious leverage there .....
If you are thinking about pulling the tree to the left in the picture (away from the shed) with your tractor forget about it. You would have better luck pulling it to either side (towards or away from the camera) - where at least you aren't fighting all the force of that leverage.
The person doing the cutting need to know how to cut a tree to get it fall in a particular direction - and what not to cut.
I'd be asking if there was some particular reason the professional didn't want to take it down when he was there .... the answer to that might tell ya alot.
   / is it safe to use a tractor to pull over a tree #5
Pulling that tree down with that tractor is almost certain death. Here is what I would do. Above the "Y" in the tree, notch the branch hanging over the shed. Make the notch on the side opposite you will pull it. Use a rope or chain to break the branch as you pull it away from the shed. Make sure you don't notch the branch too deep so it breaks off the branch, what you want to do is break the branch so it is still connected to the tree once it is twisted away from the shed. Now cut the other branch above the "Y" so it falls between the fence and the shed. Notch and pull the trunk away from the shed. The safest way is to rent a small lift/bucket and cut the tree down in 4 ft sections, or hire it out to someone with the equipment.
   / is it safe to use a tractor to pull over a tree #6
If I read it right, I think the reason the pro didn't want to do it was becouse he couldn't get his lift/bucket truck back there.
   / is it safe to use a tractor to pull over a tree #7
I have two stories to relate.
1. 30 years ago my father and I needed to cut down a dead oak. It wasn't huge; maybe 2 ft diameter. We had cut a lot of trees so we weren't newbies. This oak was close to the powerline and leaned a little towards the powerline, so we couldn't fall it towards the natural direction. (just like your mulberry) So we hooked up our Farmall 706 tractor to it with long log chains up really high in the opposite direction of the powerline. We snugged up the chain, and I cut a step V towards the tractor. As I was cutting the V, the tree started to go, I signaled my dad to go, and he started to pull the tree. You can guess what happened. It went down sideways, fortunately missing the powerline, but it gave my dad a wild ride as it drug him sideways towards where it fell. Fortunately it didn't flip the tractor. BTW, a 706 weighs like 4X what your little 4110 weighs. Knowing what I know now, I wouldn't think of doing what your thinking of, especially seeing that mulberry lean the way it's leaning.
2. I have a summer house on a lake in Kentucky. When I bought it last year, it had a new deck, porch, and the whole side facing the lake was renovated, for a reason. I was told that there was a large dead tree on the lake side of the house, and the owner tried taking it down himself. He hooked his Jeep up to the tree, notched it towards the Jeep, and when it went, it fell on the deck and house, and pulled his Jeep off the side and almost into the lake. Besides the damage to the house, they had to hire an expensive crane to take the tree off the house.
Seeing the pictures, I wouldn't personally touch that mulberry, even if it were my own tree, let alone a neighbor's. It might be simplest to drag the shed out of the way, fell it in it's natural lean, and drag the shed back.
   / is it safe to use a tractor to pull over a tree #8
I had some pros remove a few locusts from my roadside. One was leaning back a little and was tall enough to have hit the power lines on the other side of the street had it fallen naturally. They were able to use a little skid loader with a large rope attached near the top of the tree to guide its fall (one guy cutting, another in the loader). The owner was talking to me and explaining the principles of levers (not news) and, more interestingly, the properties of various trees and the amount of experience required to attempt this. From the tree type and whether it would fall well or splinter to the specifics of the tree like insect damage, etc., there are a lot of parameters that need to be considered. The final tree they didn't have a good angle so they used a bucket and brought it down in chunks.
With your tree, the only way I'd consider taking it down myself is in pieces small enough not to damage the roof of the shed (or just let it land on the shed and video tape it for use in a funniest videos submission :)). After all, that's what pros have insurance for!
   / is it safe to use a tractor to pull over a tree #9
I have pulled over many small trees with a tractor. But I don't think I would try to pull over on that big. I would, however, use a bulldozer to push it...
Just my $0.02.
Bryan
   / is it safe to use a tractor to pull over a tree #10
I'd like to suggest you listen to the people who have posted their experiences. On the other hand, if you insist on doing this with your tractor, can I be the agent who handles the video with Jay Leno?
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Cat TH407C Telehandler (A53472)
Cat TH407C...
