is it on?
   / is it on? #1
THARN
NorthEast Ohio
tc40 NH/turf tires
This may be the dumbest question of the week?..hehehe
I have a block heater on my NH- I plugged it in the other day to test to see if it was working- I'm assuming it doesn't make any noise at all because I couldn't tell if it was getting power or not. Is there a way to know if it's active?
   / is it on? #2
After a few moments, I would think you would feel some heat around where it goes into the block..... /forums/images/graemlins/crazy.gif
Mark
   / is it on?
So would I..lol
But I didn't. it was around 35f -I was reading that the item is installed 'into' the block. so maybe thats why i couldn't feel anything. /forums/images/graemlins/blush.gif
   / is it on? #4
Put an amp probe on one of the power legs.
   / is it on? #5
Hmmmm.....
Did it start up any better?
Did the temperature guage read warmer more quickly than normal?
Did the lights dim when you plugged it in.... /forums/images/graemlins/grin.gif?
Maybe it's one of those things that work when you believe in them - like sugar pills (the placebo effect)...
Mark
   / is it on? #7
On my TC18 you can definitely feel the area of the block getting warmer. Also after an extended period of time (hour?) the temp gauge will read warmer.
Follow the cord to where it is installed in the block - there is a connector there, might be loose.
   / is it on? #8
As stated, feel for heat. Also, if there is no ambient noise, you can hear most block heaters about 15 seconds after powering up.
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
CFG Industrial QK18R (A50121)
CFG Industrial...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2019 Dodge Journey GT SUV (A50324)
2019 Dodge Journey...
2015 Nissan Pathfinder SV SUV (A50324)
2015 Nissan...
2020 Ford F-150 XL (A50120)
2020 Ford F-150 XL...
