Backhoe Is it normal for a backhoe to lower a little (lose pressure?)
   / Is it normal for a backhoe to lower a little (lose pressure?) #1
ids
Hi,
I have a 5241 with a BH90 backhoe - and I don't know if I am having problems...with the backhoe attached, I might be working in the field, moving debri, etc., anything really, and every so often I have to turn around and raise the boom, it seems in about 1/2 hr of moving, the bucket lowers about 6 inches..I've then inserted the travel pins in the hoe, it keeps the boom from lowering, but the stablizers might dip down a little, a few inches..I am worried that if I spend to much time, I may not notice until the bucket starts contacting the ground
thanks
   / Is it normal for a backhoe to lower a little (lose pressure?) #2
It's normal; it's called bleed down. Your bh is much larger than mine. I put the two travel pins in, use a compression strap around the bucket, and stretch a small plastic buckle strap with an s-hooks on each end between holes in the two foot pads. I leave it this way any time the bh is on but not being used, both if parked or if doing loader work, etc.
   / Is it normal for a backhoe to lower a little (lose pressure?) #3
My hoe bucket and outriggers will leak down a little bit over time as well. But usually over a much longer period of time. Six inches of leak down in a 1/2 hr. seems to me to be quite a bit, but it probably depends on how much your's weighs. The dipper stick will definitely leak down if I forget to put the pin in due to it's weight. But not so much in a 1/2 hour as to become a problem.
   / Is it normal for a backhoe to lower a little (lose pressure?) #4
TOM, good idea with the ratchet straps. That would take all the pressure off the cylinders.
   / Is it normal for a backhoe to lower a little (lose pressure?) #5
I thought all BHs had 'parking' pins/hooks ?
   / Is it normal for a backhoe to lower a little (lose pressure?) #6
I can't comment on all hoe's but on mine I have two pins. One holds the hoe from swinging, the other holds the dipper stick from lowering. But the bucket and the outriggers have nothing to hold them in place.
   / Is it normal for a backhoe to lower a little (lose pressure?) #7
6 inches in 30 mins? that seems excessive. are your seals leaking ?
   / Is it normal for a backhoe to lower a little (lose pressure?) #8
Didn't think of this earlier. Do you have a turn valve under the seat to release the pressure when you want to lower the 3ph? If so, do you have it tightly closed?
thanks for the tips everyone...yes, it is at least 6 inches, if not more...but it could be the wheel underneath the seat - I know there is one, just had no idea that would effect any bleed - I will check..thanks
steve
   / Is it normal for a backhoe to lower a little (lose pressure?) #10
I don't think that the valve under the seat will really affect this issue. This valve is designed to slow the descent of a 3-point implement. While it may also slow the backhoe, it wouldn't prevent it from bleeding down.
I have the same issue with my backhoe and think it is a leaky valve. Apparently it is fairly commonplace so I haven't lost much sleep over it.
Mike
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
Kubota BX2230D (A47384)
Kubota BX2230D...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
