Is it level?
   / Is it level? #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Using my bota for a very rough land clearing project I tend to worry about damage to fluid lines. So I try to look at sight glass every time I climb on. Usually have white glass and then I have to figure out if bota is level-usuall not-so I worry. Problem solved. I leveled bota with 4 ft level and siliconed $2 string level behind steering col on dash. I worry a lot less now.
   / Is it level? #2
Why worry, if I were you I would lift the worrying limit 3-5 steps, and still get a good nights sleep.
This may sound negative, but is well meant.
   / Is it level? #3
Park your tractor on top of dry dirt when you're done. If there is no oil spots on the ground and the fluid level still looks ok and you don'tsee any fluid near joints or whatever you are ok.
INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
INGERSOLL RAND...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
