Is it enough? JD 4210
   / Is it enough? JD 4210 #1
rxburn
Same questions as many others but with different conditions. I will be towing this tractor a great deal. I also need to be able to get around in the woods. Fit between big trees, run over saplings. I will want to harrow and lightly grade firebreaks. I also will be doing some rotary mowing and BBing woods roads. Is 28 Hp enough? Does $13,900 new make it worth the risk if it is on the edge? I don't have many options in this area and don't want to pay the extra for a 3000 series which seems to be the same tractor in different wrapping paper. A used 4600 and a new 990 are also available local. /forums/images/graemlins/confused.gif
   / Is it enough? JD 4210 #2
If it were me I would look long and hard at the 4115 or the 4310 before a 4210. It might just be a little underpowered for the fram size. I have heard several dealers say that it is the one model they worry most about selling due to much disatisfaction with the power to weight ratio.
Thanks Mike. That probably explains why this dealer has three at a discount price.
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2015 Dodge Dart Sedan (A51694)
2015 Dodge Dart...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
Mitsubishi Mini 2WD Truck  (A52384)
Mitsubishi Mini...
Scag STT61V 61in Zero Turn Mower (A51691)
Scag STT61V 61in...
