Is hydraulic fluid all the same?
   / Is hydraulic fluid all the same? #1
Dragonslayer
McDonough, Georgia
Kubota BX 2230 D, 1939 Ford 9N
I have a new to me Kubota BX 2230 that needs some hydraulic fluid. Excuse me if this is a stupid question but is all hydraulic fluid the same or is the Kubota suggested fluid a must?:confused3:
   / Is hydraulic fluid all the same? #2
If your adding i would add the same its kubota utd or sutd do you have the owners manual
   / Is hydraulic fluid all the same? #3
IMO, if the tractor is no longer under warranty any compatible quality fluid that meets the same specs is fine...many recommend not mixing brands etc....but many have admitted doing so (myself included) without ill effects...
   / Is hydraulic fluid all the same? #4
If it has a hydrostatic transmission, I would be putting SUDT2 back in it. That is the "good stuff", I am using it in my Kioti.
   / Is hydraulic fluid all the same? #5
Answer : ... No
Many tractors use the same fluid for the transmission as the hydraulics. This places many different sometimes conflicting demands on the fluid. Tractor hydraulic fluids are thus very different than straight hydraulic fluids that are also very different ... (Non-combustible, hi-temp, lo-temp, bio-degradable, synthetic base, water emulsion, etc.)
correct answer for you... use what Kubota specifies. To do otherwise, could be very expensive later.
   / Is hydraulic fluid all the same? #6
SUDT & SUDT2 do work better in HST machines. Much less whining from the tranny. I think the consensus is SUDT2 performs better in the cold & that the pimply big advantage over the other. So a lot of warm weather dealers only stock SUDT. We use SUDT2 here in Colorado.
Other fluid will work, but the Kubota stuff is a bit better. Some the Kubota stuff is synthetic, but I believe only the SUDT2 is semi synthetic.
   / Is hydraulic fluid all the same? #7
Pardon my dumb question but is this an exclusive Kubota retailed fluid?
I saw three different brands at TSC this morning and none of them had any industry spec labels. Pretty frustrating.
Thanks.
   / Is hydraulic fluid all the same? #8
Thanks.
Yes, SUDT & SUDT2 are Kubota brands. Super UDT technically. The U might be Universal, but I'm not sure if it's an acronym or not. Likely to only find it at your dealer or online. It is a bit more than premium fluids & a lot more than the cheap junk, but worth it.
   / Is hydraulic fluid all the same? #9
Thanks.
Can't remember the brand names but both the (cheapo) black jugs at TSC and the blue jugs at Wally world have "compatible with" listing on the back labels...fwiw...
btw...UDT listed on both...
No it didn't come with any owners or shop manuals. Does anyone have a link to download the manuals for the BX 2230 D?
2019 CAT 272D2 (A42021)
2019 CAT 272D2...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2003 Ford F-650 Super Duty (A44501)
2003 Ford F-650...
2025 JMR Tree Boom Skid Steer Attachment (A42742)
2025 JMR Tree Boom...
2005 GREAT DANE TRAILERS GREAT DANE TRAILERS (A45046)
2005 GREAT DANE...
1999 Ford Econoline Van, VIN # 1FTRE14W0XHB81450 (A44391)
1999 Ford...
