Is e-hydro stout enough
   / Is e-hydro stout enough #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I had just about decided on Kubota when I took another look at JD4120 (the new 4000 series) I want to do some disking, bush-hog box blade and fel work. I went to several JD places and they said if I was plowing or disking that they did not recommend a hydro. I will be doing more fel work than the other but Kubota never had such advice. Does this mean the JD hydro is whimpy. I really don't want the e-reverser if I don't have too.
Any thoughts
   / Is e-hydro stout enough #2
Use the search feature here and you'll find far more posts than you'll ever want to read covering the hydro-vs-gear wars! /forums/images/graemlins/tongue.gif
The general reason the dealers may not recommend the hydro for heavy tillage use is you do lose some 'rear-wheel' power compared to gear (more than just the PTO numbers show) and the fear that you may overheat and potentially damage a hydro tranny in such duty. But since many here do use their hydro CUTs for small-area disk and plow use without issue - it's a matter of scale. Doing a garden? Not likely to be an issue. Doing the back 40 (or 100)? Could be.
Deere had some electronic gremlins early on, and I believe each of the other majors also have had their minor bugs. But bottom line, while there are legitimate differences in tranny type (gear or hydro) suitability for specific purposes I don't believe I've ever seen anyone post anything here to indicate that one color hydro is fundamentally more or less durable than any of the others.
   / Is e-hydro stout enough #3
How much discing? I pull a 10' JD KBA with the 4310 in A range and haven't had any problems. Heat buildup is the concern here, not parts breaking. Heat buildup on a 60 degree day is different than heat buildup on a 90 degree day and the eHydro's have a transmission cooler in front of the fan to help cool things down.
   / Is e-hydro stout enough #4
</font><font color="blue" class="small">( <font color="blue"> I went to several JD places and they said if I was plowing or disking that they did not recommend a hydro. </font> )</font>
The hydro will hold up fine and work fine,I know from lots of experience.
   / Is e-hydro stout enough #5
If your worried that you might be over doing it, put a temp gauge on your hydraulic fluid and monitor it. As stated, most folks haven't had a problem. With a gauge you can be sure.
   / Is e-hydro stout enough #6
After four years of using hydrostatic drive, I cannot get them to get to hot. I have days that hit 100 degrees and even using my boxscraper with all the rippers down full length and hours on end of ripping in low gear the hydrostatic is a marvel. My opinion is that hydrostatics are built well, at least in the brand I own which is all I have experience in.
Thanks for the info. I had planned to disc about 30 acres.
   / Is e-hydro stout enough #8
I'll echo what Rat said. I've had hydro JDs and Kubotas. The only time I've ever had the temp go up in the transmission was when I was doing bush hogging. That was because I had a load of pollen, dirt, and seeds completely cover my radiator when I was in a hilly area and the ambient temp was in the upper 90's. Once I cleaned the radiator and the screen over it, the temps immediately went down. I've never had the trans temps go up enough to notice otherwise even when plowing, disking, and tilling. I'd have to assume that any decent hydro made should be able to do the same.
2024 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2024 PETERBILT 389...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
Trojan 5T-45 36in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 5T-45 36in...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
