Box Scraper Is a Woods Rollover R30 Box Blade Strong Enough?
   / Is a Woods Rollover R30 Box Blade Strong Enough? #1
horse7
Clinton Hollow NY
I read lots of posts, and I am inclined to think that a rollover box blade is more suitable for what I want to do. With the FEL at 81" and the tire track (outer edge) around 79-80", an 84" box would be a good idea. Maybe I missed a possible vendor, but it seems like the Woods R30 would be a good compromise-- but it is rated 65hp (I have 72hp).
Soil type is decomposed shale and gravel, some rocks (some rocks are 12-24", with an occasional rock outcrop most of which I know the locations of), soil packs very well-- it is hard in other words. There will be a lot of roots in some areas, most will pop out easily but not all will.
The question I have is whether the Woods would hold up to the occasional immovable object without a case of terminal pretzels particularly wrt to the blade, or whether I should seriously consider a step up to an industrial box with hydraulic scarifiers, and just float the box with the scarifiers dropped if the ground needs multiple passes for breaking up.
[an alternative is to hire a bulldozer 2 or 3 times (multiple sessions are needed, 2 to 8 hr each, over several linear months) but I'd rather buy a new toy:D ]
   / Is a Woods Rollover R30 Box Blade Strong Enough? #2
My Mahinda weighs in at about 12,000lbs with loaded tires and my Gannon rollover box scraper has been great.:) I do not have rocks that I hit, so I can't comment on hitting immovable objects. Be sure to check out the thickness of the industrial scrapers before you buy one. I'm not sure that they are made with any thicker metal, just more of it. In other words, I'm not sure if they are actually any stronger. Search for rollover box scrapers here on TBN and you should find more info.;)
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
(10) 8' Treated Posts (A50515)
(10) 8' Treated...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
