Rotary Cutter Is a Woods BB72 to big for my JD 3320?
   / Is a Woods BB72 to big for my JD 3320? #1
mainemark1
John Deere 3320
I need to buy a rotary cutter. I have been looking at the BB60 (priced at $1600 localy). Can my tractor handle the BB72? I also will be mowing about 3 acres with this (for my camp), will this do a good enough job if I keep the blades sharp? The other use will be for me to cut about 14-15 acres of tall grass and small bushes (under 1 inch). Does anyone know if I can get one cheaper online?Thanks for your help!!!
   / Is a Woods BB72 to big for my JD 3320? #2
Do you have a FEL or other ballast on the front? My L3240 is similar to your machine and a Woods BB60 on the back is about all it can handle without the FEL or something heavy on the front, especially on ruts or hills.
I have a front end loader. My real question is can the PTO drive a 72". Also, is the price of $1600 to high for a 60".
Thanks!!!
   / Is a Woods BB72 to big for my JD 3320? #4
I believe a BB72 would be too large for your tractor. Woods recommends 30-65 PTO HP to run the BB72. The 3320 has roughly 25 PTO HP. I think you would be better off with the BB60.
Im from Presque Isle, ME (Northern Maine). Is the landpride as good as the woods?
   / Is a Woods BB72 to big for my JD 3320? #7
I like Landpride stuff that I have,,, Built good,,:)
   / Is a Woods BB72 to big for my JD 3320? #8
I have the same 3320 that you do, and went though this when buying my rotary cutter. I'm not sure about the Landpride attachments, but for John Deere you have 2 options: 72" RC2072 and the 60" MX5. Both have a minimum rating at 25HP, the MX5 is a more heavy duty unit, but the RC is a nice unit too. Price for the MX5 is $2500 and the RC2072 is $1782.
   / Is a Woods BB72 to big for my JD 3320? #9
Thanks!!!
I'd say 72" might be a bit much if you want to cut a full swath thru waist high field grass at any kind of ground speed. For lighter work it should be fine. I discovered that price can be a local matter, so maybe someone nearby can comment.
2018 Ford Fusion Hybrid Sedan (A50324)
2018 Ford Fusion...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2012 BMW 328i Sedan (A50324)
2012 BMW 328i...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2012 Chevrolet Cruz Sedan (A50324)
2012 Chevrolet...
