After recent issues with a Case IH 70a MFD I am considering buying a mx5200 or the new mx5400 with a gear transmission. My only concern is if this will be large enough. Especially since I will be coming from a tractor that is more the size of an M series Kubota.
My primary task consist of rotary cutting approx. 18 to 20 acres of open field (have 25 acres total). It is thick and frequently gets 3 to 4 feet tall. I cut it several times a year with a 6ft cutter now and with the Case 70a it takes me about 10 hours to mow at 3.5 to 4 mph.
I would keep my 6ft cutter to start but would eventually like to move up to a larger cutter, like a Woods DS8.30 pull type, Land pride rcr2596 pull type, or maybe bigger? Would a mx5200 be a good fit for these cutters? Would I be able to go 3.5 to 4 mph in taller grass?
My other concern is the weight. Will I be bouncing around a lot? My 70a is over 1,000 lbs more. I will get the loader with the Kubota, my 70a dose not have a loader on it.
I will also use it for snow blowing. My driveway is approx 500 to 600 ft. I would get a land pride sb1574. I dont see any issues with blowing snow. More concerned with rotary cutting.
What are your thoughts? I don't really want to step up to the M series because of cost and I want a loader.
