Is a Kioti CK30 $1,640 better than a NH TC30?
   / Is a Kioti CK30 $1,640 better than a NH TC30? #1
Southern Indiana
Kubota L3400 HST
I went tractor shopping yesterday and was quoted $13,340. for a Kioti CK30 4WD Gear transmission tractor and a different dealer quoted $11,700 for the similar NH TC30. No implements or additional equipment. I believe these quotes are MSRP. Both dealers are reputable.
The only differences I can determine (so far, before y'all weigh in!) are 4 yr warranty on the Kioti vs. 2 yrs on the NH and more weight in the Kioti, although NH's brochure doesn't list weight for the TC30 in 4WD.
1. Based on these prices, what do you experts feel is the better value?
2. How does a rookie tractor buyer determine what is the 'street price' for new tractors of this size?
Thanks!
   / Is a Kioti CK30 $1,640 better than a NH TC30? #2
I'm not that familiar with Kioti but they do look like a very nice tractor. My local dealer sells NH and Branson. He tried to sell me a TC30 as they are cheaper. I did a lot of research on this site however and after looking at both tractors and weighing the things I liked it was a hands down decision to buy the Branson. I have not regretted my decision one bit. The TC-30 is most likely a fine tractor but does not compare with the weight and features of a Kioti, Kubota or Branson in my opinion.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #3
Get the prices for the other items before you attempt to make a decision. There could be over a grand difference between the cost of the FEL fully installed from the two dealers. What about power beyond? Will you eventually need that? If so, get it installed before initial delivery. After you add all the other stuff in, the final price difference might be less $300 between the two packages.
I learned this the hard way when I bought a Jeep wrangler 6 years ago. Options from the factory were dirt cheap if bought with the Jeep initially. If you went back and bought something after the sale, the option prices were way higher. Running boards that were factory installed were some ridiculously low price of $65. If you bought the factory part kit and installed them yourself later it was over $100 just for the parts. Same thing with factory installed lamps for $40. Adding them later costs double.
Get everything you might possibly want within the first year of ownership included in the initial purchase. I bought my 27HP JD 790 in January. I have spent at least 50 hours shopping and buying stuff for it since then. If I had known better, I would have arranged for all these items initially.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #4
MSRP on the TC30 2wd gear is $11542 per New Holland Product Counselor, so $11,700 sounds like a good price.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #5
I was quoted 10,950 for TC30 gear model.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #6
Corriher sells the TC30 gear for $11,000.
As for is one better, that depends on your needs. Define better. Or better yet, define your needs. The TC is lighter weight so will softer on the ground, both generate the same horsepower and PTO horsepower for implments. The CK has about 100# more lift capacity on the 3pt hitch but you may not ever need that, or it may be a critical issue for you? I don't much like the operator platform of the TC30, but others swear it is great.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #7
Then you need to look harder! Isn't one blue and one orange? That's a huge difference. :eek:
   / Is a Kioti CK30 $1,640 better than a NH TC30? #8
CK30 = telescopic sway bars & lift arms, suspension seat, tilt steering, curved arm front end loader, fender mounted joy-stick, one piece hood, 4-year warranty...imho these two tractors are not even in the same catagory...so yes the CK30 is worth the extra $$!
Fair question.
I will call on my tractor to do the following:
1. Brush mowing of irregularly shaped areas, none large, and trails all of which are on slopes. I have no flat ground.
2. Future road construction and maintenance, primarily moving, placing, and grading crushed limestone.
3. Assist with firewood collection namely carrying wood through the forest to the road where the pickup truck is parked.
4. Other assorted tasks involving moving or lifting of materials.
Using tractor will be more of a 'hobby' or 'leisure' activity rather than anything commercial or daily use.
   / Is a Kioti CK30 $1,640 better than a NH TC30? #10
None of your tasks seem to be anything that will tax the capacities of either tractor. The CK has a stronger front end loader, but I'm not sure if you are buying one of those since you didn't mention it. It also has the curved arms, which make it easier to use. The CK loader also has a cracking problem but it is in the process of being redesigned so that problem may soon go away.
The TC can clearly be had for less money than you were quoted, so the increases the price difference to roughly $2340 based on the other two price quotes mentioned here. That is a lot of money. I would say it is a more traditional old-style design.
For mowing a field, I don't see either tractor using the 3pt capacity and both will operate the same size rotary cutter. Both are capable with a box blade, but the CK will offer somewhat more traction for that work. Both tractors will carry a full bucket of firewood without any strain.
One point about the warrenty you mentioned. The Kioti warrenty is 4 years on the engine/drivetrain and 2 years on everything else. Unless NH changed their warrenty, they are 3 years on the engine/drivetrain and 2 years on everything else. Further, for your reference, most manufactuers have only a 1 year warrenty on attachments like a front loader or a backhoe.
2005 GMC C5500, Duramax Diesel (A47371)
2005 GMC C5500...
Bale Spear (A47164)
Bale Spear (A47164)
2022 FORD F-150(INOPERABLE) (A48992)
2022 FORD...
International Diesel Engine (A49251)
International...
Fork Lift Block & Brick Forks (set of 2) (A49251)
Fork Lift Block &...
30ft S/A Boat Trailer (A46683)
30ft S/A Boat...
