Is a Ck front axle limited slip?
   / Is a Ck front axle limited slip? #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
Got stuck the other day installing a culvert(NO, i didn't take any pictures ON PURPOSE!:eek: ). Anyway, the rears would both spin w/dif lock on, & the LF spun, but the RF never spun. I got out by looping a chain around a tree, then around the bucket at full extension then "curling".
Later, while scooping up dirt to cover the tile, i noticed the RF spinning. So, why no spin when i really needed it?
RD
   / Is a Ck front axle limited slip? #2
Sounds like an open diff up front. In fact, I think, Rick told me the front was open.
   / Is a Ck front axle limited slip? #3
I have a CK20 and have had the front differential apart and mine is NOT limited slip.
   / Is a Ck front axle limited slip? #4
Yeah, the front differential is open. Can you imageine trying to turn that tightly with a locked front diff? :eek:
   / Is a Ck front axle limited slip? #5
Open, as stated, turning with a full bucket would be end of front end. That wheel just happened to be the light wheel each time. Push up against a tree in low, I bet you'll see other tire spin depending on how loaded.
Ok, thanks for the info. At least everything is working correctly......!
RD
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
International 3500 Backhoe (AS IS) (A50774)
International 3500...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
