Front-End Loader Is a Blackhawk loader (from a Satoh Beaver S370) fit on a Satoh Buck S470 ?
   / Is a Blackhawk loader (from a Satoh Beaver S370) fit on a Satoh Buck S470 ? #1
grandschmu
Quebec
Satoh
I have a Satoh Beaver with a Blackhawk loader and I want to know if can fit on satoh Buck without modification. Does someone have the two tractors to compare the frames?
Thanks!
After many searches, I'm disapointed that the Buck and Beaver seem no share the same frame. So the loader will probably not fit. As it is bolted to the frame, the holes will be out of phase.... :(
I must find a Buck with a loader, OR another tractor brand, similar to the Buck (small, reliable, strong, simple for repair).
Any suggestions for an alternative? Ford 1310 ? Mitsubishi MT180?
   / Is a Blackhawk loader (from a Satoh Beaver S370) fit on a Satoh Buck S470 ? #3
I just came across this thread. The Satoh Beaver had two phases, the newer phase was similar to the Buck. The mounts may not line up, but a decent welder could fabricate new mounts.
A good resource on the North American and Grey Market Satohs and Mitsubishis is Bill Rodgers at Valley Power Products. vppinc@cox.net
800 609-5110. He has parts for NA and GM machines and is a wealth of knowledge.
Hope this helps,
Utah Smitty
Wow!! Thanks a lot to all! Your informations are very usefull.
This weekend, I saw a Massey Ferguson 205-4 and I falled in love with it. It was i little bit too big for me and, of course, it had no loader... But I liked the compact format (only 55 inches wheelbase) with big wheels and a good weight!
So, I'm still continue me quest.
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
2011 Kubota KX080-3 Midi Excavator (A50322)
2011 Kubota...
Truck Tool Box (A50774)
Truck Tool Box...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
