is a 40" lcd flat panel
   / is a 40" lcd flat panel #1
randy41
Veteran Member
Linden VA
tv something that can be handled by one person? will i be able to unload it, bring it inside and set it up or is it too heavy/bulky?
   / is a 40" lcd flat panel #2
Not very heavy....should not be a problem.....
   / is a 40" lcd flat panel #3
I'd guess <50lbs. I'd be willing to set it up on a stand myself but I'd probably want a friend to help mount it high on a wall.
   / is a 40" lcd flat panel #4
The weight is not really an issue, but considering the size of the TV, where you will mount it, and the investment, I would recommend you have an extra pair of hands around to help.
   / is a 40" lcd flat panel #5
I've got a 37" LCD TV.
I carried it and hooked it up myself. It's not too bad, but I do recommend you get help...it'd be a real shame if that brand new TV got busted.
   / is a 40" lcd flat panel #6
as jdbower said - on a stand no problem, on a wall, get help. I set mine up myself in Jan. Is this your first HDTV? You'll love it.:cool:
   / is a 40" lcd flat panel #7
I have a 32" LCD. It doesn't way much more than a case of your favorite beverage ;)
If you are going to wall mount it, buy the nice brackets they sell for that purpose. Best Buy, Circuit City, etc. all sell for about 50-75.00. Don't "skimp" on it, it will have to withstand the weight for a long time.
Once the bracket is on the wall, you can easily pick up the tv and mount it on there yourself...if you have the bracket that are "made" for that purpose. Just lift, let it slide down on it, stick the pin through, wala, you're done. A lot easier than hooking up a box blade or a disk :)
its going on its stand so sounds like it should be pretty easy.
thanks all
   / is a 40" lcd flat panel #9
What Roy said... My 37" is around 50#, but it is very ackward to get a hold of for one person without comming into contact with the screen and it would be a shame to kill a new set or damage the screen trying to get it into it's new home:)
   / is a 40" lcd flat panel #10
I have a 40" Samsung, set it up myself. It would have been nice to have another set of hands, but I was too stubborn to wait for my helper, lol.
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
(INOP) 2018 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A51406)
(INOP) 2018...
Towable Diesel Fuel Tank with Pump (A55787)
Towable Diesel...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
