Price Check Is $3500 a good price for a used 4672A BH?
   / Is $3500 a good price for a used 4672A BH? #1
Chuck_S
Eastern Washington
New Holland TC24DA
I found a 4672A BH attachment close by for $3500. It's got around 100 hours on it and looks to be in good condition going by the pictures. So is that a good price? I plan on mounting it to my TC24DA New Holland via the 3PH.
   / Is $3500 a good price for a used 4672A BH? #2
It's probably a good price. From posts I've seen here on TBN you can expect a new one to be more than $5,000, maybe $6,000 prices seem to be going up.
Be careful you don't break your NH, when that Kubota backhoe goes on a Kubota tractor, the top 3-point tie is reinforced and the frame back of the axle is changed to reinforce the lower attachment points. I'd check with your NH dealer and see if there is a similar reinforcing kit for your TC24 when a backhoe is put on. NH may not need the lower frame reinforcers but probably will need the top attachment point reinforced.
The top 3ph pins for the backhoe are hardened. Regular pins will deform and be hard to pull out. If you're not sure what you're getting, buy a set a hardened pins and keep them with the backhoe when it's off the tractor.
Make sure you get the manual with the backhoe. There are a lot of adjustments on the BH to mate to different model Kubotas. You'll need the manual as a guide to try and figure out which different sets of holes and brace lengths to use in your situation.
Keep the loader on when operating with the backhoe. Besides needing the weight to offset the backhoe. The bucket set cutting edge down will help stabalize the tractor when digging.
Happy digging!
   / Is $3500 a good price for a used 4672A BH? #3
Chuck,
Where is that 4620 located? If you don't buy it I might be interested. But I live on the East Coast (Baltimore).
Thanks, Tim
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
Loflin 72in Quick Attach Skid Steer Grapple (A51573)
Loflin 72in Quick...
NEW Ripper Shank (A53002)
NEW Ripper Shank...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
Toro Mower (A50324)
Toro Mower (A50324)
