Is 3 point leak down normal
   / Is 3 point leak down normal #1
chucko
Veteran Member
Polk Co , Fl
bx1800
mine seems to be leaking down with the tractor off very slow(like over hours) is that normal?
   / Is 3 point leak down normal #2
Yes. All hydo systems will do this to some extent. Some faster than others.
   / Is 3 point leak down normal #3
don't know if it is normal or not, i know on my B2400 the fel will leak down and to test my 3 pt one time i left the rear blade a few in. off the ground and 24 hrs. later it had NOT leaked down.
   / Is 3 point leak down normal #4
The 3PH and loader on my BX2000 "leak-down" over time. Depending on the weight attached it make take anywhere from a few hours to several days. I think that is normal, at least for Kubota. A friend of mine has a 7800 and it does the same thing.
John
thanks guys first time mine did it (ok first time I noticed) but I did have a sprayer with about 30 of mix left on it.
Got to remember that parking break it leaked down and pushed agaist a box blade moveing the BX forward putting a hole in my garage door
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A53473)
2022 New Holland...
2016 KOMATSU PC360LC-11 EXCAVATOR (A53843)
2016 KOMATSU...
