Irrirgation Pump
   / Irrirgation Pump #1
farm23
Western, NC
PT-1430, Wright Z-turn mower, BCS 853
I have planted 50 sourwood trees for my bees and have a large garden. This summer I will need to irrigate the garden and probably water the trees. Using the well pump is not an option. I have stream near by I can use as a water source.
Terry at PT says the sump pump will do a good job, but does not have a pump curve. The output of up to 400 gpm is way too much as I need only 20 to 40 gpm. The 400 gpm is at max rpm and lower rpm will reduce the output but I have no idea what it will be. The stream is some 150' from the garden and there will a large pressure drop in the piping but how much this will reduce the output I do not know.
Does anyone have experience with this pump or know of another source?
   / Irrirgation Pump #2
Put a large plastic water tank on the highest point in your garden. Then use the PT to fill the tank. Let a drip system irrigate the garden from the tank water.
   / Irrirgation Pump
Moss that is a good suggestion. I would have to make the structure substantial since we often get high winds. The gust here last might were 55 to 60 mph.
   / Irrirgation Pump
Caver, I donot have enough fall in the stream for a ram pump to be effective. That was my 1st thought so I think I am stuck with some sort of mechanical pump. A hydraulic pump seems like the best route. I have looked for a hydraulic pump other than the PT but no luck in finding one so far.
   / Irrirgation Pump #6
You can buy a "semi-trash" pump for about $300-$400 that has its own engine and use the PT to carry it to the stream. I did that for my wood-chipper needs, since I couldn't find an affordable hydraulic setup...
Just an alternative way of skinning the cat... :)
The ONE thing I'm holding out for is a hydraulic winch -- they don't overheat like an electric one will, and the PTs electrical system isn't high enough output to really power an electric one, anyway...
   / Irrirgation Pump #7
How much fall do you have?
How much head do you need?
A ram only needs 2.5-3 ft head to pump water to a couple hundred feet. Don't worry about capacity. If you use drip lines any shortage in flow rates will be compensated for by longer running times.
Last year I plant 150+ fruit and nut trees and a 5 gpm flow rate is far more than sufficient when using 1/2 gallon per hour emitters.
   / Irrirgation Pump #8
I see that you planted some sour wood trees for your bees. I tried to find some sour wood honey here in Florida, but never did find any. I like the sour wood honey, and when and if you get a batch of sour wood honey, I would appreciate the chance to purchase some from you. Right now, I am using wildflower, and orange blossom honey. I use it in my coffee, and it also makes excellent honey and peanut butter sandwiches.
   / Irrirgation Pump
JJ I sent you a PM. Sourwood honey is really good and almost all is sold here on the moutain.
New Holland C238 (A50123)
New Holland C238...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
1987 Ford F-250 Wrecker Tow Truck (A51692)
1987 Ford F-250...
2024 PETERBILT 389 TANDEM AXLE SLEEPER (A53426)
2024 PETERBILT 389...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
